How can check the licence number is block on WebLM?
Issues related to WebLM
Warmian
Post by Warmian »
Hi
1. I have activate code.
2. I used function VMProtectActivateLicense to created license
3. I used VMProtectSetSerialNumber to set license Serial number and VMProtectGetSerialNumberState to check and it is OK. License Serial number save as in file.
4. I blocked licenced on WebLM
5. How can check the licence number is block on WebLM? I read license Serial number from file. Set by VMProtectSetSerialNumber and check by VMProtectGetSerialNumberState but it not check by WebLM.
Sorry for my English :)
Re: How can check the licence number is block on WebLM?
Before release a new version of your software you need to export all licenses (including blocked) from WebLM into VMP file and use this file for protection. So the new version will not accept blocked licenses.
