VMProtect Linux styles.qss doesn't appear to change the display coloring?
kev
Post by kev »
I use a dark theme on my system and have been getting very annoyed with the fact that VMProtect is ONLY using the font color from the dark theme. This creates a UI with a white/gray font on bright backgrounds. I saw there was a styles.qss included with it but changing values in there appears to do nothing to the UI when reloaded... Is there a way to force the font color or for it to accept the dark theme? I really don't like having to switch themes to use VMProtect for about 5 minutes.
On a side note... How do I know changelogs of VMProtect? I'm pretty sure my update period has expired, but not sure what I'm missing out by newer versions.
Re: VMProtect Linux styles.qss doesn't appear to change the display coloring?
Please check the 1162 build.
Here
kev
Post by kev »
Thank you very much! Fixed my issues with being able to read the font with dark mode themes.
