VMP 3.0.5 drops support for Windows XP
tmp
Post by tmp »
The procedure entry point SetFileInformationByHandle could not be located in the dynamic link library KERNEL32.dll
VMP itself won't run on XP because SetFileInformationByHandle is supported starting from Windows Vista therefore 3.0.5 drops support for this legacy OS. I had no time yet to test if this also affects protected applications (I guess it won't).
Re: VMP 3.0.5 drops support for Windows XP
so many VMP releases recently...
Thank you for your report. We'll fix it in the next build.
