Address is already used by function error
[email protected]
Post by [email protected] »
Using the `O1` option to compile the file causes address conflicts. Switching to `Ob1` allows the DLL to be protected normally, but I still want to use `O1` for compilation optimization. Is there any other possible solution?
The CMake modifications are as follows:
set(CMAKE_CXX_FLAGS_RELEASE "/O1 /DNDEBUG /GL /Zi") -> set(CMAKE_CXX_FLAGS_RELEASE "/Ob1 /DNDEBUG /GL /Zi")
[email protected]
Re: Address is already used by function error
By the way, the VMProtect program I am using is VMProtect Ultimate v3.9.4.
viewtopic.php?p=37678
P.S. You have to use code markers only when you need to protect a part of "large" function. In other cases the protection by function name from MAP/PDB is more secure:
https://vmpsoftware.com/vmprotect/user-manu ... -a-project
[email protected]
thx a lot, this is useful :)
